Previous in Forum: VSD vs. VFD (Acronym Confusion)   Next in Forum: Current Transformer Question
Current Voltage Temperature Relation During Battery Charging
06/01/2012 5:27 AM
Hi Guys, please don mean this as a learning lesson, when using a charge controller and battery temperature sensor, I would like to know when the battery temperature rises during bulk charging, is the charging voltage/current reduced. Request your professional explanation. Thanks
Good Answers: 445
Re: Current Voltage Temperature Relation During Battery Charging
06/01/2012 10:51 AM
Yes, because if it wasn't reduced the battery would charge at the original constant rate, overheat and boil out the electrolyte. The automatic controller sees the temperature rise and lowers the charging rate, a simple negative feedback controller.
For the most professional explanation RTFM (Read The Fine Manual) that comes with the equipment or use Google.
06/01/2012 2:41 PM
Register to Reply 2 comments
