Previous in Forum: Brake Paddle Unable To Withstand Leg Pressure   Next in Forum: 93 Buick Regal 3.8L
Problem by CAT 3512B Power Stations
06/01/2012 6:04 AM
Gentlemen engineers! Question by CAT 3512B power stations. When replacing the turbine there is a strong overheating vypsknyh collectors, but it occurs after the load reaches the station within 40%. Measurements were made of air pressure before the turbine, the result - the pressure is much less! Measurements are made at the exhaust manifolds. pressure is below 25%. What is the reason?
Re: Problem by CAT 3512B Power Stations
06/01/2012 12:45 PM
Good Answers: 445
06/01/2012 12:55 PM
I suggest that you read this:
http://safety.cat.com/cda/files/572741/7/3512B%20Engine-Maintenance%20Intervals.pdf?m=147861&x=7
Especially the 5th page about "Air Shutoff Valves":
06/02/2012 1:22 AM
Thanks again for your attention and sympathy :)) Problem solved, found the fault! Faulty Turbine left cylinder bank. Thank udachi.Aleksey
06/02/2012 7:35 PM
What no pics?
06/03/2012 2:46 AM
Unfortunately the cause was human error! It was not carried out inspection of truboprovda oil supply to the turbine: ((As a result of overheating and jamming Bearing slip, the yield of the turbine system.
RAMConsult (1); Samsonov109 (2); SolarEagle (2)
