Previous in Forum: IPv6 Starts Today   Next in Forum: Program for Converting Files to Pulses
Converting .asm (Assembly) into C/C++ File
06/07/2012 3:33 AM
our machine has data in .asm (assembly language) and our engineers know C/C++. how can we convert this file from assembly to C. is there any progarm/decompiler or has to convert manually line by line, the program .asm is written on 60 pages.
Good Answers: 88
Re: converting .asm (assembly) into C/C++ file
06/07/2012 6:15 AM
Most C/C++ compilers can also assemble inline code. Now if you want your programmers to maintain a possibly uncommented 60 pages asm listing they didn't write themselves, I say you are WAY too optimistic. S.M.
Re: Converting .asm (Assembly) into C/C++ File
06/07/2012 1:28 PM
Good Answers: 38
06/07/2012 10:18 PM
seems like you have to convert it manually after reading this.
http://www.tek-tips.com/viewthread.cfm?qid=534625
Good Answers: 44
06/08/2012 3:48 PM
Most any true assembly or machine language is compiled into a hexadecimal or (older) octal code, or even straight binary which cannot be interpreted by anything except a processor.
The structure that a human being needs to decipher such is the programming language from which it was derived. Once the language is compiled the pointers from the code are discarded. A processor does not need these pointers or formatting that a human being does.
Unless you are Neo or some other denizen of Zion, then you probably cannot "read" machine code the same way one "reads" a standard programming language.
Decompiling most code is nearly impossible, unless you wrote the original code and know where the data in the machine line goes. Then you can program a unique decompiler to reverse the programming.
Register to Reply 4 comments
cuba_pete (1); Epke (1); SimpleMind (1); SolarEagle (1)
