I would like to receive suggestions for the task below.
The assembly task is as follows:
A acme threaded stem (25 mm to 35mm dia) is to be be jammed with an SS sleeve 25.5 mm- 35.5mm ID, 36-46 mm OD mm.
A step cut of 2 mm deep, corresponding to the sleeve length of about 10mm to crimp the nut will be made at the end of the threaded stem.
A 1mm deformation into the step is adequate.
The length of the SS sleeve is about 10mm.
In the final assembly, the SS sleeve will act as a stopper.
I want to know if a portable equipment is available to jam an SS sleeve.
Or do we have to do it on the power-press with die set?.
Thanks
Simha
