Previous in Forum: Feed Water Heater   Next in Forum: Engine Noise
Drum Level Glass
06/09/2012 2:44 AM
WHY BOILER DRUM LEVEL GAUGE GLASS ISOLATING VALVES ARE INVERSE? NORMALLY BALL VALVE OPEN WHEN IT IS PARALLEL TO THE LINE AND CLOSE IF THE PERPENDICULAR TO LINE. SO IN DRUM LEVEL GLASS ISOLATING VALVE ARE INVERSE IN DIRECTION, WHY?
Re: DRUM LEVEL GLASS
06/09/2012 8:18 AM
I would blame the valves, not the drum level sight glass. Check the valve handle orientation to ensure they are mounted properly. The sight glass should only be a visual double check to ensure your sensor readings are accurate on the water / steam level in the drum.
Drew K
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Drum Level Glass
06/10/2012 2:03 AM
  • Gravity
  • Fail Safe
Should the packing be loose and thus let the handles "fall", the valve will always be open. Kind of silly since the steam/water will also be passing at that point (or shortly thereafter) but, the intent of the ancient boiler designers is clear.
Best regards, HeviiGuy
06/11/2012 1:42 AM
I can't remember the exact reason but I do believe that it is some kind of standard.
Swimming Pool valves are exactly the same
Cheers
Joe
Register to Reply 3 comments
BoltIntegrity (1); Drew K (1); Joe Sparky (1)
