Previous in Forum: Watts Reader Direct to Grid   Next in Forum: Quick Three-Phase Motor Coil Connection Question
Need Help to Communicate Parker Servo Drives via SLC 5/03
06/10/2012 1:44 AM
Dear Friends,
We have a setting machine in which 20 Parker Servo Drives and motors (name plate images attached) used to place the tools at desired position. The control system is a very old, PC based having MS DOS. The PC communicates with all drives via an RS232/485 converter and then a daisy chain to all drives.
As we have been facing problems with the control system, so we have started working to control the servo drives via an available SLC 5/03 and I/O cards. So I have two tasks to do now;
--> First make a parameter setting so the motor rotate in both directions if pressing FWD or REV P.Button.
--> Second, make a communication link of SLC 5/03 and drives to run the motors via PLC.
I need help from my friends how to attain that goal as i don't have any experience with servo drives in past. I read the manual of drive but need some help to complete the task.
Thanks in advance.
Re: Need Help to Communicate Parker Servo Drives via SLC 5/03
06/10/2012 9:10 AM
Parker still exists and still makes some excellent motion control systems. You should contact them directly.
Good Answers: 804
06/10/2012 11:52 AM
Or contact L&T in Lahore for help with the AB PLC, there is a Serial Comms card available to give you an RS485 port. One way or the other, this is way too complicated for Internet forum help.
Register to Reply 2 comments
