Previous in Forum: Every Day Stress   Next in Forum: Grounding Materials
10 comments
Electrical Question
06/24/2012 6:13 AM
24volt AC coil connected to 24volt DC supply coil is not magnet, why?
Good Answers: 181
Re: electrical
06/24/2012 6:19 AM
It burnt out!
Re: electrical
06/24/2012 6:22 AM
Broken?
Fuse blown?
Good moaning!
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: electrical
06/24/2012 10:28 AM
It is only a coil without iron core.
Re: electrical
06/24/2012 10:29 AM
Your English is not clear and precise. So I am not certain what problem you are having. Please clarify what you are doing, especially if none of my guesses are correct.
You may have an under sized 24VDC power supply. If the 24VAC coil is rated to draw 0.5A with a 24VAC source, when a 24VDC is applied the current draw will be considerably higher because the coil inductance will not limit the current. If this current level exceeds the capability of your supply that you sized based on the AC current rating then the supply will protect itself and shut down.
You may not have just an AC coil. This package (relay?) may have a DC blocking capacitor in series with the coil to prevent DC current from leaving a residual magnetic field in the core.
You may even be trying to detect the magnetic field improperly.
Re: electrical
06/24/2012 10:46 AM
AC and DC don't mix well....
Re: electrical
06/24/2012 10:56 AM
Since when? They mix all the time.
Re: electrical
06/24/2012 12:09 PM
Yes where they are engineered to do so....Using AC voltage on a DC designed circuit or vice versa doesn't work well...
Re: electrical
06/24/2012 11:48 AM
24v AC is about 34v peak to peak, thus 24v DC may not be giving sufficient voltage to operate whatever it is you are trying to energize.
Re: electrical
06/24/2012 12:41 PM
Its not peak to peak but peak voltage. In AC voltage across inductor is I.XL where XL= 2.pie.f.L
Re: electrical
06/24/2012 1:14 PM
'Peak' and 'peak to peak' are both perfectly valid measurements.
Anyhow, it's doesn't matter a jot what you call it.
The fact of the matter is the wobbleosity of 24vAC gives more thrunge than 24v DC
Register to Reply 10 comments
Anonymous Poster (1); Crabtree (1); hithuanand (1); redfred (2); SolarEagle (2); TonyS (1); user-deleted-1105 (2)
