Previous in Forum: Manufacturing Plant   Next in Forum: Request Material Grade Standard Convertion from UNI to AISI
Can Savalgnini L1Xe Laser Cutting Machine Cut Titanium
06/26/2012 6:32 AM
Hi guys,
I need to Know that wether Savalgnini L1Xe (laser cutting machine) can cut Titanium with thickness 0.6mm and thickness 1.5mm
Is kind urgent now, appreciated you guy help as soon as possible
thanks
Re: Can Savalgnini L1Xe Laser Cutting Machine Cut Titanium
06/27/2012 8:15 AM
Yes it can be done but
titanium burns when subjected to the laser's heat. See this article:
http://www.thefabricator.com/article/lasercutting/shop-perfects-laser-cutting-brass-titanium
06/27/2012 9:28 AM
By the way, you need a class "D" fire extinguisher to put out Titanium fires. Fires can also start during regular machining.
From Wiki:
Sodium Chloride (Super-D, Met-L-X or METAL.FIRE.XTNGSHR) contains sodium chloride salt and thermoplastic additive. Plastic melts to form an oxygen-excluding crust over the metal, and the salt dissipates heat. Useful on most alkali metals including sodium and potassium, and other metals including magnesium, titanium, aluminum, and zirconium
Register to Reply 2 comments
