Previous in Forum: KVAR Savings Calculator   Next in Forum: Power Cable Type
Software for Reading Program in UD77 of Control Technique
06/27/2012 1:03 AM
Dear friends,
We have two control technique inverter drives UNIDRIVE UNI3405 to control the operation of plate forms of down stackers. The drive has a Device-net communication module UD77 which has a program to receive/send information to OMRON PLC. I want to read that program for which I need some kind of software. I asked Control Technique from their web site that which software do I need but still no reply. There are a list of software available at Control Technique web site but need information which software can fulfill my requirement. Please help.
Control Technique Software
Re: Software for Reading Program in UD77 of Control Technique
06/27/2012 11:33 PM
module UD77 is made for Device-net, so you cann't read its program, but you can configure this module by entering parameters data through drive keypad then it can communicate with OMRON PLC and if you want to observe such data you must entering PLC program.
Eng.Ihsan
06/28/2012 5:48 AM
Hi Ihsan,
But in the machine manual, OEM stated that a program has been developed in UD77 with Control Technique software. I need that software.
07/06/2012 3:14 PM
Signode,
I have been worked with that tip of regulator and I used program UniSoft but I could not find it on the list.I will check full name of program for couple days because I am away from work.Good luck
09/18/2012 8:21 AM
our website at www.emersonct.com/download_usa/software/Usoft343.exe
There is link for Unisoft program if you did not solve problem.
Good luck
03/14/2016 2:41 PM
dear signode,
did you find a solution to read this program? it seems we have the same machine, and i need to change these drives from unidrive classic to a new version.
thanks a lot
hassan
Eng.Ihsan (1); Hassan2016 (1); Panta SD (2); Signode (1)
