Previous in Forum: Freezing Hot Water vs Cool Water   Next in Forum: Corrosion Difference Between 304 and 316
14 comments
How to Seamlessly Join Stainless Wire Without Welding
06/28/2012 2:17 PM
How can I join stainless wire together without access to welding apparatus ? Adhesive? Solder? Doesn't have to be strong ,just appearance on wife's knic knack stuff lol
Re: How to seamlessly join stainless wire without welding
06/28/2012 2:23 PM
Twist it.
Good Answers: 125
Re: How to Seamlessly Join Stainless Wire Without Welding
06/28/2012 2:44 PM
Use an Angler's knot.
06/28/2012 2:49 PM
06/28/2012 5:24 PM
I think some overlap will be necessary, but soldering, or even a good adhesive should work.
A histroical note: Many years ago, I compared surface preparation methods for adhesive bonding of stainless steels, using the ASTM overlap shear panel bonding technique.
Of sanding, glass beading and wire brushing, wire brushing produced the highest bond strengths. All methods produce acceptable results.
Good Luck.
Good Answers: 38
06/28/2012 8:22 PM
like a Blacksmith?
Good Answers: 58
06/28/2012 8:59 PM
Super glue comes in thin and thick, a gel. If that's not good enough, you can solder it, but it takes a special flux. Check with a jeweler for the right stuff.
mike k
06/28/2012 11:56 PM
I work with small diameter (<.050") stainless steel wire and tubing everyday. For quick prototyping, you can join it with silver solder and flux. Stainless is more difficult to solder than electrical wire, but not impossible. You need a very clean soldering iron tip (wire brush to remove any oxides) and then clean your stainless steel wire with rubbing alcohol (isopropanol) to remove any oil residue. Then treat the surface of the wire to be soldered with any flux designed for soldering stainless steel. After treating the surface, apply some silver solder to the soldering iron tip and transfer the molten solder to one of the wires to be soldered, this is called "tinning". Tin the other wire tip and the hold both tips together end to end or in a twist and apply heat to them via the soldering iron tip. The solder will flow and wick onto both wire tips creating a nice, even solder joint. Clean the soldered joint in rubbing alcohol. I would use an acid free, water soluble SS flux like one of these: http://www.superiorflux.com/stainless_steel_soldering_flux.html
Good Answers: 102
06/29/2012 1:32 AM
You're not going to make much progress trying to silver solder with a soldering iron.
Soft solder (like what is used for connecting conductors and tin smithing) absolutely.
Have a close look at a pre MIG/TIG welding era SS urinal and you will see the soft soldered joints.
Ask an old plumber he'll tell ya.
Good Answers: 29
06/29/2012 2:31 AM
Three or four ideas here that don't require welding or silver solder or fancy prep work.
You should be able to find stainless tubing in an I.D. just a few thousandths larger than the O.D. of the wire your wife is using. Pieces of this small tubing are available at our local Hobby Lobby in the beading section, and so are very small diameters of brass.
Insert the ends, crimp with a tool you find appropriate after experimentation. Done.
My mom can't squeeze the crimpers that hard, so she just smashes the tube twice on each end with a ball-peen hammer against pop's old bench vise anvil. Yes, I've shown her how to crimp the tube by crushing it with the vise jaws. She likes to smash it because it's faster.
If you can't find tubing small enough, you can also bypass the two ends to increase the diameter inside the tubing, even thread in extra fragments of wire if you need more filler.
I've seen some of this done where six or seven or eight loops were all joined into one compressed tube using this method.
It's not very reversible, but that's kinda the idea. It doesn't come apart.
Last, you can fold the ends of the wire back on itself to make small folded hooks. Hook the two ends together, leave the ends of the hooks spaced a little, and wind this connection with fine single strand copper wire. Solder the copper wire as you would any copper. No need to worry about the stainless prep work.
I also have seen some of the RC model guys use gel cyanoacrylate to bond stainless inside tubing. They claim it's permanent. Probably not to high heat but you are talking jewelry and knick knacks so this could work also.
txmedic3338
Good Answers: 58
06/29/2012 7:55 AM
Fishing supply stores carry many fasteners to join stainless steel wire. However, welding works so well and is so easy. You may not think you have access to welding equipment, but there is so much of it available at such reasonable cost on Ebay and other sites, that I wouldn't rule welding out.
06/29/2012 8:15 AM
nickle wire is easier to solder. i would suggest filing the ends to a 45 degree angle. solder using the correct solder and flux. file smooth. buff
06/29/2012 8:24 AM
I use a silver/tin solder every day to join small pieces of stainless steel; you have to get it to 600+ deg. F to flow. The comment about stainless steel hypotube is a great one, definitely the best so far.
06/29/2012 9:56 AM
Get some fine stainless steel wire and do as a fisherman would, if you don't know what he would do just ask one, or just pull the satinless steel wire through both of the two pieces of netting at once, then tie off!
Spencer.
07/01/2012 4:58 AM
http://www.verdigrismetals.co.uk/mortise%20and%20tenon%20joints.htm
or you may go nuts attempting this
(muh ha ha ha haa)
ci139
Register to Reply 14 comments
Calnet42 (1); ci139 (1); durtieduck (1); Epke (1); lyn (1); mike k (1); SolarEagle (1); troiano (2); txmedic3338 (1); Wal (1); welderman (1); WJMFIRE (1); xanasax (1)
