I have a forging made of 45Mn. C .42-.50;Si .17-.37;Mn .70-1.00;P,S <0.035;Cr <.25;Ni <.30;Cu <.25;
I want the the part have minimum .02% Al.
Because factory usually use the Al to refine the steel.Could the Al leave in the steel more than .02%?
Is there any body tell me how much will the factory use Al to refine the steel?
Cast,Forge,Weld,Machining,Screw,Nuts,Valve,Pump
