Previous in Forum: Reliable tank container provider in China   Next in Forum: At our side, you can see what kind of traffic signs?
Steel tube produces how to operate the machine?
07/03/2012 10:28 PM
Do you know how to operate Steel silo production machines?
The following is a summary of my steps, the hope can help you.
Bend bite suture machine- -and to link pillar framework for-and molding machine decoiler in place.
The first step: bend bite suture machine on steel and the cylinder body (the wall) of circles (round used a line outside of school coincidence). At the same time calculated the spiral rises a quantity, in the end of the machine a leg of the pad is appropriate under pad.
Step 2: the prop, the frame before connection, should be adjusted according to the requirements pillar. On request to build silos (the wall) of circles, pillar of the wheel on the projection points along the circumference and long term should be coincidence (with the fall of the). From the bend bite machine counterclockwise, interval 1.6 meters installed a belt, has been installed at the last root and bite machine bound together form a closed framework. Pillar is building steel warehouse (pool) is an important support parts quality and safety of the important link, therefore when installation must level (note: with each of the root of spiral liters).
Step 3: molding machine in principle on bite machine suture machine clockwise about 5-6 meters near the silos (pool) the inside edge.
Step 4: uncoiler on 2-3 meters after molding machines, main effect is the upper placed 495 mm wide plate.
Such HD-40 steel belt molding bite suture unit in place was finished, already have started working conditions. But in order to ensure the quality and safety, should also be idle operation commissioning ten minutes to check the machine running status of each wheel. And then feeding forming 4 meters long two paragraphs. Artificial up and down together into the bite suture machine, in two sections of steel plate after the bite bite muscle place, grinding wheel cutting sampling, to observe the quality situation after bite, decided to formally to boot operation.
