We have several buildings where the HVAC system is controlled by small ECUs that are 24VAC 100va that I need to find power conditioners that will carry the units through short term power losses up to 500ms. These units, provided by Johnson Controls, (about 150 in three buildings) drop their program and restart with a program upload when a voltage drop is sensed causing a loss of building control. A small in line unit with replaceable, rechargeable battery backup to carry through power dips is needed. I have researched every manufactureer and found only one manufacturer that has units in design and testing. It would be good if the unit was UL listed. Does anyone know of a manufacturer or an available source?
