Previous in Forum: Solenoid Valve Burning Problem   Next in Forum: Weld Joint Stregth
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Ventilation Rates
07/17/2012 5:30 PM
Ventilation rates given by ASHRAE Standard 62.1-2004 and the International mechanical code are different, with the latter being usually more than the former. Also, one is a standard while one is code that is required. Nonetheless, which value is it good engineering practice to use?
It is better to fail in originality than to succeed in imitation.
Re: Ventilation Rates
07/19/2012 9:23 AM
As far as I know, we are not required to use the "International Mechanical Code" (what is the body that produces this?) in Canada. In our designs, we use ASHRAE 62.1 - 2007.
Given that ASHRAE is developed by engineers, and IMC is by Building Code Officials, I would suspect engineers would advise going with ASHRAE...
07/21/2012 3:18 AM
Generally ASHRAE standards are preferred. You can still consult the local government codes if any available and compare it and take decision in consultation with experienced consultants.
Register to Reply 2 comments
