I am specifically seeking responses from US/ CANADA, Europe, India, China based responders.
Do you what is this lamp? Do you have personal experience of using it or seeing it? Here are some very interesting links
http://www.tedgreenroom.com/TEDGreenRoom/Blogs/Green_Electrical_Sells/Energy-efficient_lighting_savings_proven_in_the_field.aspx
http://www.transparencymarketresearch.com/latin-america.html
Here is some extract
n both cases actual energy and cost savings were quantified by using small light sensors installed on the luminaires in order to log light levels every five minutes. Captured data was then used to calculate energy consumption, vacancy percentage and cost savings.
The project energy and maintenance savings was projected for both demonstration sites as a Total Life-cycle Cost with the following findings:*
Metal Halide: $3192 vs. the Induction Retrofit: $880 = a total savings of $2312
High-Pressure Sodium: $2578 vs. the Induction Retrofit: $1211 = a total savings of $1367
Data such as this certainly helps during the sales cycle. For other examples, check out www.energy.ca.gov/research.
*Calculations were based on 4380 annual hours of use, Energy Cost: $0.128/kWh, Cost of labor: $100/hour, and Time to replace lamp: 0.5 hrs
I look forward to more personal experiences, opinions of future vs-a-vis LED technologies (which I think has no future- as you must have seen from several blogs on CR4 itself- fading LEDs)
