Previous in Forum: Sewage gas smell at the sink   Next in Forum: Suitable place for 20 years experienced graduate civil engineer?
19 comments
Calculating Cubic Yards of Concrete
05/15/2007 10:59 AM
The gentleman in the office next to me is having a new concrete sidewalk poured. When he called the concrete company, he was told when calculating cubic yards of concrete divide the square footage by 80.
I've calculated several different areas using the "standard" methond [(area in sq.ft x 0.333')/27cu ft per cu yd] and the numbers come out very close.
My question is how is the above "80" derived?
Thanks!
"Life is not a journey to the grave with the intention of arriving safely in one pretty and well-preserved piece. The intention should be to skid in broadside, thoroughly used up, worn out and defiantly shouting, "Wow! What a ride". -Unknow
Pathfinder Tags: calculation concrete cubic yards
United Kingdom - Member - Member
Re: calculating cubic yards of concrete
05/15/2007 11:14 AM
cubic yards = square feet/80
therefore
cubic yards = square yards/9 (approx)
so the "sidewalk" will finish 4" deep
Im no expert in this field but this is the only sense I can make out of it. For a 6" deep sidewalk you would divide the square footage by 54 although the concrete company would probably tell you to divide by 50 for ease.
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Good Answers: 40
Re: Calculating Cubic Yards of Concrete
05/15/2007 12:02 PM
The standard sidewalk is 4" deap. Any thinner and it will have a tendancy to crack
3' X 3' X 3' =273 feet = 13 yard of concrete
in a cubic foot you can get 3 of 4'' X 12 X 12
3 X 27 = 81
The standard sidewalk also used to have an expansion joint ~ every 4' the expansion joint was typically filled with a material that looked like 3/4" or 1" thick tar paper
80 was derived at by taking into consideration this joint.
05/16/2007 3:44 AM
That's silly. If your allowing for joints then you need less concrete not more! Any number divided by 80 is going to be greater than that same number divided by 81.
Good Answers: 266
05/16/2007 1:51 PM
Were talking about pouring concrete not rocket science. Close to 4" deep is good enough. Ever see a concrete worker with calibers and micrometers to get just prefect. Be an expensive sidewalk
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
05/15/2007 3:05 PM
for a 4 inch thick slab
4" = 0.333' 1/0.333 = 3 3*27 = 81
For a 6 in thick slab
6" = 0.5' 1/0.5 = 2 2*27 = 54
for a 12 inch thick slab
12" = 1' 1/1 = 1 1 * 27 = 27
All the concrete guys did was solved half of an equation with standard values and made a conversion constant. Hope this helps.
05/16/2007 1:12 AM
Mathematically, if L is in feet, W in feet, and T in inches, compute volume in cubic yards (L x W x T/12)/27= volume in cubic yards.
For practical purposes when you order read-mix-concrete you need to round-off the volume to the nearest high number.
"The more I learn, the more I know the less I've learnt"
05/16/2007 8:02 AM
Ok , lets not get so technical with a simple question !
any concrete finisher will tell you that the simple way(maybe not the precise way) they determine how much concrete to pour is take the square footage divide by 80, then times that by the thickness to get the yardage to use. The reason being is because how many footings and thichnesses of concrete are absolute. They all vary, just depends on who's digging and building the form are if you even have a footing. So put your slide rules away you don't need them, just get some old concrete finisher and pay him the 60 cents a square foot (thats what i paid last)to do it all for you
05/16/2007 8:40 AM
Thanks for all of your help!
Darvin
05/16/2007 11:22 AM
W X LENGTH X THICKNESS DIV BY 345 GIVE YOU THE EXACT YARDS
05/21/2007 3:49 PM
Dividing surface area by 80 is clearly a good, time-tested, rule-of-thumb, for estimating the volume of 4" concrete slabs, such as sidewalks. However, there are other factors at work. First of all, a sidewalk is typically "formed" on a levelled layer sand or (semi-?) compacted earth layer that is within a few hundredths of a foot of the desired level. The usually wooden forms are placed along the full length of the sidewalk. Those forms are usually "2x4's". The concrete is subsequently poured and then screeded, floated, finished and sometimes brushed to it's final, pre-curing elevation(s). However, said 2x4 may only provide a guide level of 3'-1/2" above the sand/earth. For those situations, it mght be better to divide the surface area by about 92.6 (= 3.5 x 27). And further, the sand/earth floor may well absorb much of the water in the concrete mix, and a little of the concrete itself, depending on the compaction of the sand/earth and the water content of the concrete. So, it might be better to divide by about 90 instead. Plus, you should always allow a few percent for wastage, etc. And this is a simple(?) application......
05/21/2007 4:15 PM
.......... and, of course, it's always better to double-check one's calcs before clicking on "submit" (blush, blush...)
Let me formally issue an addendum to read " 92.4 (= 12 X 27 / 3.5") "
And if the sidewalk went across a commercial driveway, it would need (woven wire mesh ?) to strengthen it against loading heavier than merely (domestic) traffic, which would further reduce the quantity of concrete required in the same space by ..........
11/04/2007 6:55 PM
Hey hey, New guy here, make this real easy for everyone, and any one that is looking for easy answer. http://www.concretenetwork.com/concrete/howmuch/calculator.htm
04/17/2008 8:20 PM
Gee guy your lucky if you get 70 not 81 Concrete company know how to fill the truck to there likings. Forget math or add in human greed factor
Been doing this for years 80 is your best number spillage plus if you are using more than 5 yards add 5%
Side walk are usally scraped out using 2x4 a 2x4 is 3.5 inches thick
Always watch for that because 3.5 will crack a lot faster than 4
10/23/2008 1:09 PM
For a 4 inch depth: Divide (Length*Width) by 81 derived from: 3 * 3 * 3 * 3
The first factor of 3 is derived from converting the 4" depth to Square Feet (4 / 12 = .33): Square Feet = (Length * Width) * .33 or Sq Feet = (Length * Width) / 3
The remaining three factors of 3 are derived from converting cubic feet to cubic yards, one factor of 3 for length and one factor of 3 for width and one factor of 3 for depth as follows:
Length (in Cubic Feet) / 3 = Length (in Cubic Yards)
Width (in Cubic Feet) / 3 = Width (in Cubic Yards)
Depth (in Cubic Feet) / 3 = Depth (in Cubic Yards)
02/18/2009 2:39 PM
Divide 27 by .333. Typically sidewalks are 4" thick (.333). He just figured the SF and divided by 80, rather than multipling by .33, then dividing by 27.
09/20/2026 8:05 PM
The 80 is basically a quick field shortcut for a 4" thick slab. One cubic yard is 27 cubic feet, and 4" is about 0.333 ft deep:
27 ÷ 0.333 ≈ 81 sq. ft.
So dividing the square footage by 80 is just a rounded version of the more accurate divide-by-81 calculation. For example, 800 sq. ft. ÷ 80 = 10 yards, while the exact calculation gives about 9.88 yards.
Your standard method is the better way to handle different thicknesses. The 80/81 shortcut really only makes sense when you're assuming a 4" slab.
For quick checks, I sometimes use a concrete yardage calculator rather than redoing the conversion each time. It’s handy when you’re dealing with different slab thicknesses or dimensions.
09/25/2026 11:12 AM
That “divide by 80” rule is basically just a shortcut for a 4-inch-thick slab, with a little extra built in.
For an exact 4" slab:
1 sq ft × 4/12 ft ÷ 27 = 0.01235 cu yd
So you’d divide the square footage by about 81.
Using 80 instead assumes about 4.05 inches of concrete, which gives them a small cushion for uneven ground, waste, etc.
So your calculation is right. 80 is just a contractor-friendly rule of thumb.
MalcAndCheese
Indonesia - Member - New Member
10/08/2026 9:42 AM
The “80” is basically a shortcut that assumes a 4-inch-thick slab. One cubic yard covers about 81 square feet at 4 inches thick, so dividing the square footage by 80 gives you a slightly conservative estimate. If the sidewalk is thicker or thinner, though, you’d want to use the actual thickness rather than the 80 rule.
10/09/2026 1:22 PM
For a quick check, you can also plug the dimensions and thickness into https://www.concretecalculatoronline.com/ and compare the result with the shortcut. It’s useful when you have several sections with different dimensions or depths.
Register to Reply 19 comments
Anonymous Poster (7); AvatarIndo (2); Bolton_Alan (2); DMcGowan (1); MalcAndCheese (1); ozzb (1); Richard L (1); Seanrose (1); srnick34 (1); techno (1); willyap06 (1)
