Previous in Forum: Delta Transformation Question   Next in Forum: DC Current Blocking Diode
Malaysia - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Education - New Member
3 Phase AC Motor
07/26/2012 9:46 AM
why voltage measured in star setting is different compare to delta setting??
# I Never Met A Revolutionary Who Can Build What He Destroys # *Sultan Abdül Hamid II*
Good Answers: 137
Re: 3 Phase AC Motor
07/26/2012 11:14 AM
Because the internal wiring is different. In star there are in effect √3 x as many windings as in delta, so voltage is √3 higher.
07/26/2012 2:19 PM
Read this article
Three-Phase Transformers
07/26/2012 5:46 PM
First define where do you want to measure?. Phase to phase or Phase to netral
B.E, M.I.E, M.S
Good Answers: 181
07/27/2012 6:56 AM
This may help
07/27/2012 9:18 AM
Dear TonyS
Please note that what you have shown in diagram is already shown by mathematically and vectorially in my comments in the previously posted title " Re: Voltage Equation dated 08/03/2011 12:32AM"
B.E, M.I.E, M.S
07/27/2012 11:30 PM
ok,tq....
07/30/2012 4:35 AM
You need to refresh your basics from any standard text book/literature on the subject.
You may recall that, in case of STAR ,the line current & phase current are same.But ,the line voltage is \/3 times the phase voltage.
However, in DELTA ,the phase voltage & line voltage are same,where as the line current is \/3 times the phase current.
From above,you can see that,line voltage of STAR is \/3 times that of DELTA ,where as line current of DELTA is \/3 times that of STAR.
Learning is a never-ending process.
Register to Reply 7 comments
Codemaster (1); HAIKAL HAMDAN (1); Mushtaq Hussainh (2); nobodysomebody47 (1); spradhan (1); TonyS (1)
