Previous in Forum: Marshalling Kiosk   Next in Forum: Effect on Voltage by Adding Resistance on Analog Output
Malaysia - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Education - New Member
Dahlander Motor / Dual Speed Motor
07/27/2012 8:17 AM
1) How rotor in dahlander is rotates,since there is no electrical supply in rotor to create a polarize field??
2) How RMF is produced in dahlander motor??
# I Never Met A Revolutionary Who Can Build What He Destroys # *Sultan Abdül Hamid II*
Re: Dahlander Motor / Dual Speed Motor
07/27/2012 8:43 AM
Good Answers: 69
07/27/2012 9:08 AM
A dahlander motor has squirrel cage rotor, the magnetic field generated by the stator induces a current within the bars of the rotor, which in turn generate a magnetic field of the same polarity, thus they repell.
You don't need an auxiliary winding to start rotation, since a three phase stator produces a revolving magnetic field around the core, causing the rotor to spin.
Regards
Register to Reply 2 comments
