Previous in Forum: Design of Electromagnet Coil   Next in Forum: Touchstar Finger Print
Cannot Assign IP Address
07/29/2012 10:47 AM
Hi All,
i've bought 3g router and printer. i've assign my printer ip into 192.168.1.150
after configuring the ip of the printer then i've configure the same ip into the 3g router/modem but i am getting error " ip address invalid" any advise.
i am using DWR-112 3G route/modem.
Regard
Re: connot assign ip address
07/29/2012 11:23 AM
Did it come with any instructions?
SG IP Locator
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Cannot Assign IP Address
07/30/2012 8:59 AM
If you are using DHCP, the router will have a range of valid addresses to dole out. If the router is sitting at 192.168.1.0, the valid DHCP range may end at 192.168.1.100. You should be able to change the DHCP range to suit your needs, or you can change the printers IP to an address that is within the routers default DHCP range.
Tom D.
08/12/2012 5:52 AM
Hi All,
Many thanks i already engage IT to configure my printer. my router IP is 192.168.0.1
Regards
Anonymous Poster (1); lyn (1); tdesmit (1)
