Previous in Forum: Mercury Villager/Nissan Quest Power Steering   Next in Forum: Power Steer Momentary Freeze
Fire Detection and Fire Suppression System
07/29/2012 5:03 PM
Hi
what do you recommend for fire detection and fire suppression system in diesel generator in the train?
Pathfinder Tags: fire diesel generator
Re: Fire detection and fire suppression system
07/29/2012 5:13 PM
This is Automotive.
Can you provide some clarity? Size of generator?
Drive train? Freight train? Gravy train? Soul train?
08/28/2012 1:56 AM
this is a wagon which generates the eletricity of the train. it is inclued two diesel generator and a switchgear room. The dimension of the mentioned wagon is as follows:
width: 4m, length:21m and height:2m
I have to design an automatic fire extinguishing system. what system do you recommend? (Fire extinguisher are water, CO2, inert gas, etc.)
thanks for your comments.
Good Answers: 123
08/29/2012 1:00 PM
Dry powdered fire extinguisher systems are the best for liquid fuel fires. Pressurized water, or water with a foam agent added will cool and extinguish a fire also, but the dry chemical has the ability to smother better. Contact a professional in your area.
Bob
07/29/2012 5:46 PM
Keep it clean and well enough maintained and it should never start on fire.
08/29/2012 12:50 PM
I am looking for a person who could clean the mentioned wagon. I definitely pay a good salary for it. if you can, please contact us.
Good Answers: 123
07/29/2012 6:17 PM
Check with the authority having jurisdiction over the area that the train will operate in. Find out what their minimum requirement is. Then contact a licenced fire extinguisher business to have them install and maintain the system With proper documentation.
If there are no requirements, it is hard to beat the combination of a trained human and dry powder fire extinguishers. Think of twenty pound extinguishers as the smallest size to use. And multiple extinguishers are a must. 20 pounds will allow some good knock down power before going empty. And multiple extinguishers allow for multiple extinguishment points at the same time, and for the possibility of relighting after the initial extinguishment. Think of how many people might be on that train when there is a fire. Now think about that many lawyers trying to take the shirt off of your back. Good luck.
Bob
Register to Reply 6 comments
bob c (2); lyn (1); talebi (2); tcmtech (1)
