Previous in Forum: Hydrogen Detection   Next in Forum: Can You Paint A Evaporatived Swamp Cooler Made Of Polyproplene Plastic
Plugged/Unplugged Vent of PSV
07/31/2012 12:58 AM
Hi!
I've noticed in API 520 that conventional PSV's vent is plugged while the balanced ones aren't. Does anyone know why is it so??
Thanks in advance!!!
Pathfinder Tags: plug PSV vent
Re: Plugged/Unplugged Vent of PSV
08/01/2012 2:29 AM
Some of the PSV's are coming with plugged (red sign with PSV) from manufacturers to make site hydrostatic test after installation on the process. Some of the PSV's plugging on site to make hydrostatic test.
All the plugs are must be removed after hydrostatic tests, before operation.
Regards,
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
08/01/2012 9:11 AM
I thought that the balanced valves would vent to indicate that the bellows had broken and you were now exposing the back of your relieving piston to the back pressure of the flare/vent system. No need to do this on the conventional valve since the relieving piston is already "seeing" the back pressure of the flare/vent system.
Money doesn't talk, it screams in your face.
Register to Reply 2 comments
