Previous in Forum: Stand Pipe   Next in Forum: Fill Water
Loop Tuning
08/02/2012 7:58 PM
I have tried a few methods of tuning, more trial and error.I did find one in our company documents,but I cannot find out what the L is for.
The formula is Ti=((30+3R)/(9+20R))*L
R=ratio of the tangent of the x axis.
Re: loop tuning
08/02/2012 8:51 PM
I have no idea what you are trying to do, tune for, what two angles(?) make a ratio of tangents and I have no idea what L might mean except maybe length. Usually Ti indicates the metal Titanium but I doubt that you are trying to attempt metal transmutation or alchemy.
Please provide us some more information.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: loop tuning
08/03/2012 6:45 AM
By historical convention, the Ziegler-Nichols open-loop tuning method labels the "reaction rate" of the process as R and the dead time of the process as L.
Here is a link to a website where an engineer has re-published Ziegler and Nichols' original 1942 paper on the subject (with permission). It's a fascinating document, and well worth the time to read for anyone interested in the origins of these tuning methods:
http://www.driedger.ca/Z-N/Z-N.html
Note that this paper was written in the era of pneumatic controller mechanisms, and therefore all signal values are expressed in PSI (pounds per square inch air signal pressure).
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Re: loop tuning
08/03/2012 9:25 AM
Nice paper.
This might be what the OP is talking about. I did not see the equation in question in that paper but I did not look very hard either.
Good Answers: 46
Re: loop tuning
08/03/2012 10:11 AM
You are exactly right: the OP's equation is not part of the Ziegler and Nichols' original recipe for PID tuning. It was only because I saw the "R" and "L" terms that I concluded he was doing open-loop tuning.
In practice I've found that either Ziegler-Nichols tuning method -- open-loop or closed-loop -- provides mediocre control quality at best, and for this reason there's probably a wide range of formulae yielding tuning parameter values that will more or less work.
Another factor explaining variations in tuning formulae is the range of units you find in modern controllers for the integral (reset) term: repeats per minute, seconds per repeat, etc. Also, you have a wide range of algorithm options such as parallel versus series (interacting) versus "ISA", whether or not derivative acts on error or PV alone, whether or not proportional action works on error or PV alone, etc. Many of these options simply didn't exist in 1942.
On a more general note, most loop tuning problems in my experience are caused by field instrument troubles, such as valve stiction, and therefore cannot be "tuned away" in the PID controller. Also, technicians and engineers alike generally lack a strong conceptual grasp of how and why PID is supposed to control a loop, so they end up plugging numbers into formulae expecting to get usable P, I, and D parameter values. Most techs I've worked with don't know how to do anything but blind trial and error tuning, while most engineers I've worked with don't know anything but theoretical solutions based on first having a Laplace transform function of the process (good luck with that!).
One of my heroes in this field is Michael Brown, a South African control engineer who writes extensively on the subject of PID loop optimization, and whose "Case History" documents are priceless:
http://www.controlloop.co.za/
Re: loop tuning
08/04/2012 3:36 AM
I know I didnt provide enough information but I was hoping someone would have recognised the formula, I did more research and found what I was looking for,the above formula was from Cohen Coon, I think he improved Ziegle-nichols method of open loop Tuning.
Anonymous Poster (1); redfred (2); tonykuphaldt (2)
