Previous in Forum: Valve pressure rating.   Next in Forum: The Swimming Girl
Hydraulic Pistons
08/27/2012 3:35 PM
2 hydraulic pistons one working from 12 oclock towards the center the second from 6 oclock towards the center. each applies 1 ton of force on a central rubber block. How much total force is applied in the center when both are pushing to the center?
same scenario but from center to 6 oclock and from center to 12 oclock, how much force is applied (when both are touching each other in the center and are pushing out) at 6 or 12 oclock?
same scenario one cylinder at 6 pushing to the center second in the center pusing to 12 oclock. if the 2 cylinders are touching each other how mujch force is applied at 12 oclock
Pathfinder Tags: hydraulics
Re: hydraulic pistons
08/27/2012 3:50 PM
Have you checked the last few pages of the quaint and curious volume from where this question originated? Answers are generally printed there.
If the solutions have been removed, what do you think are the correct answers? We may be able to help you arrive at your solution if you let us know what you are thinking.
08/27/2012 3:51 PM
2,0,0.
Tell us what you are really trying to do.
Are you still trying to compression mold brake pads?
08/27/2012 4:08 PM
Sounds like basic hydraulics or force vector homework to me.
Good Answers: 114
08/27/2012 4:21 PM
Vectors. action and reaction.
Register to Reply 4 comments
Doorman (1); lyn (1); passingtongreen (1); tcmtech (1)
