Previous in Forum: Drop Pressure for Cracked Gas   Next in Forum: How Does a Hydraulic Actuated Diaphragm Pump Work?
9 comments
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Solidworks Model Making
08/30/2012 3:43 PM
To other lazy engineers out there..
Is there a simple way to make a solidworks model from real part without measuring it.. I have a surface with features that are irregular and would take hours to measure.
Any ideas? Picture, scale issues etc..
It is better to fail in originality than to succeed in imitation.
Good Answers: 918
Re: Solidworks Model Making
08/30/2012 4:25 PM
There are various 3D scanners that will do that. We have one (can't think of the brand/model) to scan flight grips and small objects for our business.
There are companies out there that will perform scans of objects for a fee and give you a Solidworks compatible file.
There are a number of ones that you can buy. This is one example of many out there.
08/30/2012 4:29 PM
$2,995 for a 3D scanner!
08/30/2012 4:33 PM
How many time $$$ to measure and model... each piece?
08/30/2012 6:07 PM
$3K ?...Yeah so. It's intended for businesses. That's cheap. The software we use for design and analysis is $24K...per seat!
Then again your handle is "Economist" so...
Good Answers: 918
08/30/2012 7:13 PM
If you can't justify that cost, then you will have to pay for someone else to do it.
No sense buying something you will not use often enough to pay for itself.
08/31/2012 12:28 AM
I can't tell if your exclamation point is because you think $2995 is expensive or because you think it is inexpensive. Assuming it can do what is shown with a reasonable amount of time and effort, I find it incredibly inexpensive. For comparison Check out Nikon or Faro...
08/30/2012 7:58 PM
Since you admit being lazy, my advice to you is to send/take it somewhere where the pros are.
Unless you have the desire and the time select the system, order it, set it up and de-bug it, seek professional help.
08/31/2012 9:19 AM
CMM.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
08/31/2012 9:15 PM
Your asking how to reverse engineer an object.
The two most common methods use either white light or laser scanning technology to generate a 3D "as built" point cloud that can be rendered into a surface model. White light is generally considered to be more accurate but is the most expensive. Software such as Geomagic, Polyworks or Rapidform are used to create a usable model. You should probably contract this out. The model will dimensionally mirror the sample part so it will probably need to be tightened up (edited) to be used for your application depending on form, fit and function.
Form
  • the shape, size, dimensions, mass and/or other visual parameters which uniquely characterize an item. This defines the "look" of the part or item. Sometimes weight, balance and center of mass are considerations in 'form'. Color can be in general considered in 'form', except when has a specific functional meaning.
Fit
  • the ability of an item to physically interface or interconnect with or become an integral part of another item or assembly. This relates to the associativity of the part in relation to the assembly, or to other parts, and includes tolerances.
Function
  • the action[s] that an item is designed to perform. This is the reason for the item's existence, which also includes secondary applications.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Register to Reply 9 comments
Anonymous Hero (2); dkwarner (1); Doorman (1); Economist (1); lyn (1); markar (1); ronclarke (1); TerraMan (1)
