Previous in Forum: Energy Saving by Motion Sensors   Next in Forum: Circuit Design
Impact on Bus- Switching On of Transformer
08/31/2012 1:42 AM
Tr-4 ( 40/50 MVA- 66/33 kV with 15 % Z) is to be switched on from 66 kV existing bus which is supplied only from existing TR-1 ( 50 MVA , 220/66 kV -15 %Z ). 220 kV side bus has fault level of about 5000MVA and 66 kV side has 25 KA for 3 sec. What would be the impact on 66 kV bus in view of voltage drop or inrush current . Whether it is advisable to switch it on or not. What is normal time of inrush current of such Transformers ? I wnted to attach a sketch but could not do so .Pls advise how to attache files/attachments.
Re: Impact on Bus- Switching On of Transformer
09/02/2012 7:53 PM
You can use the Insert/Edit Image button (the Green Camera) or you can try a copy paste direct into the post reply.
Reply to Forum Thread
