Previous in Forum: 48 V AC control   Next in Forum: Air Conditioner Runs off Solar
Electrical Question
08/31/2012 2:35 PM
What is the difference between tpn mccb and 4 pole mccb? Why do we use tpn instead of 4 pole mccb?
Good Answers: 181
Re: Electrical Question
08/31/2012 3:05 PM
All 4 contacts break at the same time in a 4 pole MCCB. In a TP+N neutral breaks just after the phase contacts.
Good Answers: 34
08/31/2012 3:55 PM
TPN will mean triple pole with Neutral. TPN will mean a 4Pole device with 4th Pole as Neutral. 4 pole mccb has 4 poles. Basically both look same, except the current carrying capacity of neutral pole is less than the other poles.
09/01/2012 12:09 AM
Go through the recent threads,you will find the answer.
pnaban
Good Answers: 170
09/02/2012 3:12 AM
In TPN (three pole + neutral) breakers, only three phase poles would have the releases (thermal & magnetic) and the fourth neutral pole is only a switch without any releases in it. Whereas in four pole breakers, all the four poles would have releases. But, this is more a feature in MCBs only and NOT in MCCBs. In MCCBs you either have three pole or four pole. TPN MCCBs are unheard of as a product. May be, a three pole MCCB with external isolable neutral is called a TPN MCCB is tender specifications.
The choice of Three Pole MCCB + Isolabe Neutrla over a four Pole MCCB is economical, as the first arrangement is chaeper than the second.
Hope it is clear.
electricalexpert65 (1); Joshi (1); pnaban (1); TonyS (1)
