Previous in Forum: Peltier Effect   Next in Forum: Define Power Factor
8 comments
Engineering Fields - Control Engineering - New Member Uruguay - Member - New Member
Micro Relay Help Needed
05/17/2007 10:23 AM
Hello to everybody I need to replace a micro relay installed in a machine. The data that I can see are:
NAIS J1 1P 24 V
Thailand AJQ 6342
Spule 24 VDC
10 Amp 250 V
Cos phi 0,4.
I have looked for in Internet but the only thing that I found is that it belongs to Matsushita Electric
Can somebody help me on the characteristics of the relay?
Qty of contacts, switching frequency, etc
Thanks a lot!
Alvin
A pessimist, is an optimist with experience...
Pathfinder Tags: rele
Re: Micro Relay Help Needed
05/17/2007 11:06 AM
Try looking for Panasonic relays. I can't match this exactly but it is made by Panasonic.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
05/17/2007 11:13 AM
Hi BrainWave
I search for Panasonic and I found the NAIS in this brand, but like you, I can`t find the same reference. Do you know another place to search?
Thanks
Alvin
05/17/2007 6:55 PM
Manufactures change their type numbers so often and replace old with new so it is not very easy. I think this may be a single pole 1A type If you can remove it from the PCB you can check it with a multimeter by energising it and checking with the meter on the ohms range X1, and see what connects where, they often have the pin out on the bottom. The physical layout is most often the problem when trying to find a replacement. The coil position ref to the contact pins. If you can post a photo it would help. You could try contacting the following www.farnell.co.uk
05/18/2007 8:11 AM
Ok BrainWave, you're right about manufacturers changes. I can't remove it from the PCB because is very dificult due the format.
I'm looking now at farnell.co.uk.
Thanks
Alvin
05/18/2007 9:42 AM
check for an internal diode fault the diode is often included in the relay to prevent damage to the driver circuit, mostly an external one is also fitted to just make sure, it could be the driver as well that is in trouble.
05/18/2007 1:21 PM
Ok
I'll check it.
Thanks again
Alvin
05/25/2007 3:24 PM
************** Quote ***********
NAIS J1 1P 24 V > <M1P shows single-pole, 24V Coil [Spule 24 VDC] below
Thailand AJQ 6342
Spule 24 VDC
10 Amp 250 V > < Contacts Ratings:
Cos phi 0,4. > <Load's PF which can be switched safely
************** Quote Ends***********
The physical size [W x L X Depth] Canned in 1/2 can size or Full-can-size?
Type: Sealed [Hermatical or normal]
Number of Pins is required to ascertain if it is a Change-over [SPCO] or just On-Off contacts[SPST]
Mounting: PCB or chassis mount [In a socket or a Flange-Mount.
#[micro relay ]and Posting #4 indicate that it should be a PCB mount, but ...
Space available in Machine: can another be fixed somewhere in the system & wirinf brought to PCB ?
05/25/2007 3:34 PM
Hi Haajee
Thanks for your info.
We already have offered to our client a replacement relay, 24Vdc Coil and 1 SPST for PCB Mount.
Regards
Alvin
Register to Reply 8 comments
BrainWave (3); Haajee (1); orientaltec (4)
