Previous in Forum: Grounding Electrical Meter   Next in Forum: LED Driver
LV Breaker Testing
09/08/2012 9:04 PM
Hi, Guys
We have an assignment to test LV breaker make Schneider Electric Model NW20H1with logic controller 2.0A draw out type by primary injection. Once the breaker is drawn out, we are unable to manually charge the closing spring.
Can some one guide us that what protection is restricting the charging mechanism. Is it undervoltage protection or some thing else?
If any one encountered similar problem and found the solution. please guide us.
Thanks.
Good Answers: 34
Re: LV BREAKER TESTING
09/08/2012 11:27 PM
Appears like some mechanical deformity of a vital component.
09/09/2012 5:40 AM
Does the breaker spring charge electrically? If it does, May be your spring charging lever is faulty.
Above every knowledgeable, there is a more knowledgeable one.
Good Answers: 181
Re: LV Breaker Testing
09/09/2012 7:03 AM
Contact Schneider, I had a similar problem and the technical team guided me straight to the problem.
09/10/2012 1:19 AM
This is a mechanical issue and should be sorted out with maker.
Best Regards, Shivaram
Register to Reply 4 comments
Afaga (1); Joshi (1); shivaganti (1); TonyS (1)
