Previous in Forum: Design of Hydraulic Cylinder   Next in Forum: HVAC Chilled Water in World's Tallest Tower
Jet Engines - Reduce Fuel Consumption & Increase Efficiency
09/11/2012 6:30 AM
why the gas from the nozzle cant be used again so that heat energy can be further recirculated to reduce the fuel consumption and also increase the efficiency?
Pathfinder Tags: jet engines
Good Answers: 181
Re: Jet Engines - Reduce Fuel Consumption & Increase Efficiency
09/11/2012 7:04 PM
Look at http://cr4.globalspec.com/thread/80347
Asking twice will not change things.
09/13/2012 8:50 AM
If your asking twice results from not understanding or from different word definitions, i.e., do you mean "gas turbine" instead of "jet engine" then you should attempt to state where the confusion seems to be located, if possible.
Register to Reply 2 comments
