Previous in Forum: Worm Gears for Cargo Elevators   Next in Forum: UNIFLAIR AHU Minimal Fanspeed Change
8 comments
Porosity Consideration While 1 D Numerical Coding of Regenerator
09/11/2012 11:58 PM
How do I consider porosity of porous material (phi) for cell volume into 1 D numerical coding by Finite volume method? Actually I am doing coding for regenerator used in cryocooler. Do I use volume of porous material as (phi)x(delta X)? Where delta X is width of a cell under consideration? What about free flow area for calculation of heat transfer coefficient? If you have any suitable paper, please attached here.
Paresh B. Gujarati
Re: Porosity consideration while 1 D numerical coding of regenerator
09/12/2012 1:34 AM
Does a sieve have permeability of 1.00?
09/12/2012 2:19 AM
Right Now, I assumed porosity as 0.6 for wire mesh.
Paresh B. Gujarati
Good Answers: 34
Re: Porosity consideration while 1 D numerical coding of re-generator
09/12/2012 2:54 AM
Where your calculation will lead you to, when it is based on assumptions? An assumed result/answer?
Good Answers: 34
09/12/2012 2:56 AM
And what will be your assumption tomorrow and the day after?
09/12/2012 3:09 AM
Thank you Mr. Joshi for response. I am just developing the code based on the equations not by value. I will later put actual value by measurement of porosity. If you know the answer how to calculate volume for 1 D cell, then just tell otherwise do not ask superfluous questions.
Paresh B. Gujarati
Good Answers: 34
09/12/2012 3:50 AM
Good Answers: 102
09/12/2012 11:19 PM
What's with the attitude sport?!!
Good Answers: 183
09/12/2012 8:11 AM
I had a look at the questions you put. Most of them could be answered by simply using a search engine. Why do you not do this first ?
As for the porosity have a look at the Darcy coefficient which is characteristic for flow through porous media.
The sieve porosity depends on the ratio free area to total area and cannot be set as one will wish.
At the indicated address you have a good book you should look at.
Register to Reply 8 comments
Anonymous Poster (1); Joshi (3); nick name (1); paresh_career001 (2); Wal (1)
