Previous in Forum: Low Powered Ceilling Fan   Next in Forum: Is it Possible to Make Free Energy Device?
T5 28W/54W Tube
09/27/2012 1:55 PM
I plan to replace all existing T5-28W tube to 54W tube in my office.
I worry the existing tubes set / lamp holder might be designed for 28W capacity, electronic ballasts (built-in to the lamp tube holder) may not works property or even be damaged.
Anyone has such an experience?
Thanks
Good Answers: 34
Re: T5 28W/54W tube
09/27/2012 2:21 PM
Get complete new fixture for 54W tube.
Re: T5 28W/54W tube
09/27/2012 3:19 PM
T5,(28w) T5HO(58w), T18 and T12 ballasts are not compatible because the lamps operate on different currents. Even T5 and T5HO lamps can't be used with the same ballast.
Commercial Lighting Tax Deduction
Re: T5 28W/54W tube
10/14/2012 3:42 PM
Does T5HO contain mercury?
Good Answers: 73
Re: T5 28W/54W Tube
09/28/2012 12:04 PM
Lyn is right. The same size bulb will operate at nearly any current level if you have the correct ballast. Changing from a 28 Watt bulb to an High Output 54 Watt bulb will accomplish nothing without a change in ballast.
The lamp will operate a little hotter but the socket is probably the same socket used in all fixtures. Still, you may want to try one before you commit.
In general, the wattage is increased by increasing the arc (bulb) length and supplied lamp voltage (lamp voltage at about 10 volts per inch) at rated lamp current. If you double the lamp current you get High Output lamps. If you triple the current you get Very High Output lamps. Of course the electrode has to be beefed up with increased current or it will fail prematurely.
Messing with either lamp voltage or current, to change the wattage, requires a different performance level for a ballast.
You might consider buying the highest lumen output color for your 28 watt lamps. Colors are not all the same. You will pay a little more for a "designer color" but you will get more light output for the same 28 watts. It pays to read the catalog carefully.
Register to Reply 4 comments
Joshi (1); lyn (1); NotUrOrdinaryJoe (1); youngken (1)
