Previous in Forum: Metals and DI Water   Next in Forum: Piston top and combustion chamber coatings
SS 304 limpet coil failure
05/19/2007 4:34 AM
Hi
We have encountered failure in SS304 limpet coil (pitting specially in weldments)in plug and batch type reactor.The coils are welded around SS 316 reactor and circulate steam at 135oC temp and 4kg/cm2 pressure,28 % calcium chloride brine(-10oC Temp) and cooling water alternately to maintain reactor temperature.
  1. Can anyone guide me regarding suitability of this metallurgy for such a demanding application
  2. Can the failure be controlled by application of nitrite based/molybdate nitrite based inhibitor.which one is better for this application.
tanks,
Re: SS 304 limpet coil failure
05/19/2007 10:22 PM
Is it possible that the materials used in the limpet coil and their temperatures and pressures were not advised to the original equipment manufacturer [OEM] for the reactor?
If so, then an urgent request for advice from the OEM would be a good starting point.
05/19/2007 11:40 PM
300 series stainless cannot withstand chloride ion, only 400 series (and more exotic materials) can be used in brine system, especially at elevated temperatures (ie. steam heat to flush out cold brine as you switch from cool to heat).
You now have billions of small cracks throughout your system. It is like swiss cheese, and is destroyed most likely. While you might patch the leaks by something like rad leak stop in the short term, the pressure structure may fail catastrophically under pressure. Throw it out & start all over again. Next time, start by getting expert advise to design the system. Suggest process engineering firm.
05/20/2007 1:28 PM
Your system is inherently unsafe. 300 series stainless steel CANNOT be used in the high chloride service you describe. It will suffer aggressive stress cracking and suffer brittle fracture-probably without warning-though small leaks MAY appear first.
You should immediately discontinue using the equipments, decommission and scrap it, and reconstruct using a material suitable for the service.
Keith E Bowers, PMP
Good Answers: 243
05/20/2007 10:06 PM
Good evening Sangeetadixit.
I have my corrosion data at work. Will look at this in the morning.
The weldments failing first is not surprising. Usually the heat affected zones adjacent to the welds are more susceptible than the base metals being joined.
I'm not familiar with the use of nitrite inhibitors. I think that the question needs to be asked if the wedments were passivated after welding.
We'll talk in the morning
milo
05/21/2007 8:52 AM
Good evening Milo
As per equipment manufacturer ,the welding is done through special electrode technique.For control of failure during operation they recommended molybdate -nitrite inhibitor. Still within 2 Years of installation there is a failure in around 2-3 units.What is the procedure for passivation of weldment
Sangeeta
Good Answers: 243
05/21/2007 10:15 AM
Sangeetadixit:
You have been given great advice by the others. 304 (18-8) stainless and Chloride are bad combination. pits, stress cracks, and corrosion are likely due to chlorides, which according to my reference (Carpenter Stainless Steels Manual) you can expect corrosion rates to be upwards of 50 mpy (mils penetration per year). This is in inches, mpy/39.4= mm/y
Passivation will not help you given the fact that your base grade is incompatible with your fluids. However the basic passivation technigue is clean degrease to remove oils weld flux and other soils; immerse in nitric acid, rinse and dry.
Another technique that is used is the A-A-A technique-
1) clean degrease
rinse
2) 5% Sodium hydroxide 160oF 30 minutes
rinse
3) 20% by vol nitiric acid + 22g/liter sodium dichromate at 120o F for 30 min.
rinse
4) 5% by Weight sodium hydroxide 160o F 30 minuts
rinse.
This allows the alkaline solutions to neutralize any acid being retained in nonmetallic inclusions.
Based on your description of duty cycle and materials involved, i would NOT want my daughter to work in your shop, or within a mile or so downwind.
milo "heed the others- you have bad troubles !"
01/21/2026 11:18 PM
SS Engineering, Mumbai, is a top limpet coil reactor manufacturer, delivering efficient, high-quality solutions for heat transfer in chemical processes. Precision-built for durability, performance, and optimal industrial productivity.
SS Engineering
Register to Reply 7 comments
Anonymous Poster (2); Keith E Bowers (1); Milo (2); sangeetadixit (1); sseindiacom (1)
