Previous in Forum: Looking for Gas Proving System Design   Next in Forum: OTDR
Field Bus Barrier
10/03/2012 7:54 AM
Hi I am a instrumentation engineer and I need one clarification on this below. We are using a control valve in a gas pipe line with some field bus instrument. The recommended power supply specification for this field bus is
Ui=17.5V , Ii=380mA, Pi=5.32W, Ci=1.76nF, Li=0uH all in maximum rating . But one of our supplier recommend the following rating 14.8V, 359mA, 5.31W, Ci=0.50μF, Li=550μH maximum power supply unit. This is suitable and if not match what are the ratings should be considered?
Good Answers: 34
Re: Field Bus Barrier
10/03/2012 9:29 AM
Your supplier stands warranty, therefore..... You should follow his recommendation, but ask for written recommendation.
