Previous in Forum: Bus Bar Fault Current Calculation   Next in Forum: Induction Motor Torque
Multi Speed Starter.
10/04/2012 12:07 PM
Is there something called multispeed starter.Or is it a general name for starters which can vary speed.I need a detailed explanation,any links where i can read about them will be appreciable.Thank you very much for your time.
Re: Multi speed starter.
10/04/2012 12:13 PM
Multispeed motor starters: Motor windings in multispeed squirrel-cage motors may require special starters.
Go here: Motor starters - Electric Motors & DC Motors - Machine Design
Pretty common, I guess.
Good luck.
Good Answers: 804
Re: Multi Speed Starter.
10/04/2012 1:13 PM
A multi-speed MOTOR is a motor which has a winding configuration that allows it to spin at different distinct speeds depending on what winding, or winding pattern, or voltage, is selected. To do so, you need a way of selecting the different speeds and that would be a multi-speed STARTER. That can be two speeds, or three speeds, I've even seen 4 speeds, although that is rare. There are multiple types of multi-speed motors, too many to describe here, especially since you don't offer what your power supply is.
The alternative is a Variable Speed situation, which has then another bunch of sub-groups. But Multi-speed and variable speed are NOT the same thing. Variable speed implies INFINITELY variable (up to the maximum design speed of course).
10/05/2012 12:49 AM
Refer pole-changing motor and starter.
pnaban
Register to Reply 3 comments
JRaef (1); lyn (1); pnaban (1)
