Previous in Forum: Relation Between Pressure and Kinetic Energy   Next in Forum: Temporary Increase in Fault Level
About Battery Bank Layout
10/11/2012 12:25 AM
Recently I have come across a battery Bank Layout.This set up is new to me and I have not seen such till date. The specification of cell (battery) is " Valve Regulated Lead Acid ( VRLA)-Maintenance Free Battery-Having Electrolyte Confirming to :IS 266 (H2SO4)-Gas Generation for Single Cell=6.6 cc/cell/Hr-Gassification Voltage per cell=2.4 V/cell.It is 220 V/1500 AMPHr rated total cells=108 Nos.These batteries are filled with acid and charged( ready to use).What surprised me is the installation of each battery as each battery is installed in horizontal configuration ( the terminals and the hole plugs are kept horizontally and connected through copper strips/cables(inter stack). Total 108 batteries are put in 3-Nos of stacks (40+32+36) and all batteries are kept horizontally.I would like readers view whether this configuration( Horizontal laying of batteries) is correct.As I have always seen The Umbrella mark on battery pack-to be kept always upright. How the gases will come out as the electrolyte would cover the hole plug,what about leakage.Whether this configuration is correct or new technology of installing batteries?
Re: About Battery Bank Layout
10/11/2012 1:39 AM
Yes , this kind of setup is available. The battery is VRLA ( Valve Regulated Lead Acid) type , it is not the conventional flooded LA battery , you might have seen in substations. In VRLA design , the battery electrolyte is either a Gel ( H2SO4 + silica) or AGM ( Absorbed Glass Mat). The valve is a relief valve and opens in case of over pressure. The design is such that the gas generated is recombined again to make up the water loss. If you over charge or charge at a higher rate , then the valve may operate and spill some amount of electrolyte ( GEL). as per this design , the battery can be mounted Horizontal also. Hope this helps you.
Reply to Forum Thread
