Previous in Forum: Pressure Design Thickness of Con or ECC Reducers   Next in Forum: Boiler Classification on the Basis of Temperature and Pressure
Help in Caeser
10/12/2012 11:07 AM
I have following confusions regarding my project.
1. As our pipeline is very long (700Km) with seven pump stations, should we model the entire line or few pump stations?
2. We are placing supports in +Y and guides on nodes. What should be the initial spacing between the nodes?
3. If we model the whole pipeline or few pump stations, how should we calculate the optimum spacing between nodes? The problem being that if we model the whole line or even few pump stations, the hit and trial method would be time consuming.
4. Is there any method in CAESAR to define a support for multiple node numbers simultaneously?
Also, is there any other way to model and analyze the system (for example a few kilometers?)
Good Answers: 61
Re: Help in Caeser
10/12/2012 3:47 PM
Just my opinion.
1. You should break it up into manageable segments no less than:
  • each pump station or part of a pump station
  • each segment between the pump stations or part of a segment
2. With the information you have provided so far it is not possible to answer this question. Is this pipeline:
  • all above ground?
  • all underground?
  • some above ground and some underground?
  • What is the commodity?
  • What is the Code"
  • What is the Ambient installation Temperature?
  • What is the maximum operating Temperature?
  • What is the operating Pressure?
  • Where is this project located (in general)?
3. If the pipeline is all above ground then the size and schedule of the pipe determines the maximum spacing of the pipe supports. If the pipeline is all underground then the pipe has continuous support.
4. You do not have CAESAR determine the support spacing. You set the spacing based on the pipe size and schedule then use CAESAR to check for issues related to normal Pipe Stress Analysis.
5. Yes. See #1.
As I said before you have not given us much information so we really do not have much to offer. Sorry!
Do it once and do it right
Re: Help in Caeser
10/12/2012 4:06 PM
1. It means that I select the segment between one pump station (lets say 100 km) atleast for analyzing.
2. the pipeline is all above ground. the code is B31.4. The operating temperature temperature and pressure is 35 degree Fahrenheit and 1644 psi respectively. The pipeline is between USA and CANADA.
3. Size and schedule is 18inch and 60 respectively.
Re: Help in Caeser
10/13/2012 2:47 PM
Consider contacting the good folks at COADE for recommendations on your rather unique piping system.
This seems to be a case far from the ordinary, and, it sounds like you do not have a strong piping stress analysis background.
There is a great guy called Richard Ay who is very helpful there.
This is a legitimate copy of CaesarII that you are using.......Correct ????
Good Answers: 11
Re: Help in Caeser
10/15/2012 9:23 AM
Stress analysis is typically trial and error. I just did one on a few compressor stations that took me a month of moving supports to minimize loads.
The best thing to do is follow good engineering and design practices as a start for your spacing. You're not the first person to run a pipeline so you shouldn't try to start from scratch.
This spacing might be in the pipe design handbook or something. If you can't find it then you might want to do a trial and error analysis of 1 segment with 1 support at each end. Figure out your spacing from that and use that as a first guess in the real analysis.
Register to Reply 4 comments
Anonymous Poster (1); azam (1); cingold (1); PennPiper (1)
