Previous in Forum: Over 80, Electrical Engineerng Articles   Next in Forum: Replacement VR3 Regulator With VR6
10 comments
Isolation Transformer
10/14/2012 3:16 AM
Hi
Can anybody tell me that what is the per phase current of 3 phase, 200KVA Isolation Transformer?
Pathfinder Tags: isolation transformer
Good Answers: 181
Re: ISOLATION TRANSFORMER
10/14/2012 6:06 AM
No, not without a voltage.
10/14/2012 6:17 AM
3 phase voltage is 415 volt line to line
Good Answers: 181
10/14/2012 7:30 AM
278.2A
Re: Isolation Transformer
10/15/2012 5:12 PM
Muhammad Salman
What is your position?
Are you an engineer?
10/16/2012 12:00 AM
Hi
If you dont mind can you share the calculation how you got the answer as 276.4A,What is the power factor you have taken,what the formula you have used
Good Answers: 15
10/16/2012 3:16 AM
The 278A was right. Where did 276A come from? Power factor????
10/16/2012 12:30 PM
Its 278 A typing mistake
Good Answers: 15
10/16/2012 12:40 PM
line current
200 000 / 415 / 1.732
where 1.732 is square root of 3.
ans - 278.25A
10/16/2012 11:47 PM
Thanks for the reply , Is there any isolation transformer which is having power factor more than .8. If so what are they , What are the moderntype of transformer where to reduce traditional loses
Good Answers: 15
10/17/2012 3:39 AM
Don't you determine the pF by your connected load? Put a resistive load on and you can forget about pF. With a load of lossy motors and inductive lighting .......
On a decent transformer losses will be minimal.
Suggest you get a senior electrical guy on board to check what you are doing.
Register to Reply 10 comments
Anonymous Poster (3); Muhammad Salman (1); silverfox (3); TonyS (2); wareagle (1)
