Previous in Forum: A Good Renewable Energy Webiner   Next in Forum: Earthing Resistance
Harmonic Measuremnt
10/22/2012 8:51 AM
I have some harmonic values from a HV system. They were measured based on the IEC standard. My concern is this: I have values such as mininum, average, and maximum( i.e. Vrms.) within the time interval of 10 minutes, which level I should use to evaluate the maximum permisible level as specified in the IEC (IEC call them compatibility values).
For instance: within 10 minutes window I got the following values for the 5th harmonic
Minimum 1%
average 5%
maximum 8%
then the IEC limit is 6%. So should I say that the 5th harmonic is out of range based on the maximum value or is within ragen based o the average value?
Good Answers: 34
Re: Harmonic Measurement
10/22/2012 9:13 AM
One should go by the max. value.
Re: Harmonic Measuremnt
10/26/2012 9:43 AM
The compatibility levels described in IEC standards should be considered as long term limits. the exact statement is:"by convention, the compatibility level is chosen so that there is only a small probability that it will be exceeded by the actual disturbance level".
So, if the maximum value of 5th harmonic voltage (8%) is observed during short times, everything is OK.
Generally, the Power Quality is assessed by using statistical analysis. For example: 95% of the 10 minutes measurements during a given period must be below the maximum limit.
Check EN50160 (Voltage characteristics of electricity supplied by public electricity networks) for more information.
