Previous in Forum: Valve Water Sealing   Next in Forum: Standard for Combination Head and Dial Caliper Gauge
Small Cng Storage Cylinders
10/24/2012 11:24 PM
Hello, I am trying to find small cylinders (1 gge or less) to store natural gas in at about 1500 psi to 1800 psi. Also storage cylinders to store up to 2gge. Thanks in advanced to anyone who can help. Much Appreceiated.
Pathfinder Tags: Cng compressors Cng fueling
Re: Small Cng storage cylinders
10/24/2012 11:30 PM
Have you looked here: Search GlobalSpec?
A gallon's not much.
Good Answers: 34
10/25/2012 2:35 AM
You will find a few Small Cng storage cylinders manufacturers in this link.
Re: Small Cng Storage Cylinders
10/26/2012 4:29 AM
For others GGE = Gasoline Gallon Equivalent. And in this case that would be a US gallon (1 UK gallon = ~1.2 US gallons)
FROM http://www.consumerenergyreport.com/2009/06/19/how-much-natural-gas-to-replace-gasoline/
_______________________________________________________________________
"A gallon of gasoline contains about 115,000 BTUs. (Source: EPA). The energy
content of this much gasoline is equivalent to 45 trillion BTUs per day. The energy
content of natural gas is about 1,000 BTUs per standard cubic foot (scf)."
So at just over 100 atmospheres you will require about a cubic foot of cylinder storage to be equivalent to one US gallon of gasoline.
See the links from other posts above for cylinders.
Good Answers: 58
10/27/2012 8:27 AM
You may want to look at "lecture cylinders" and "pony bottles". Both are small, high pressure cylinders. Pony bottles are used by SCUBA divers as a back-up reserve of breathing air. Lecture cylinders are as the name implies.
Register to Reply 4 comments
Joshi (1); lyn (1); Randall (1); welderman (1)
