Previous in Forum: Submetering   Next in Forum: Service factor HELP!
Transformer
05/21/2007 5:20 AM
Dear All,
i am Working as a purchaser i want to purchase transformer kindly advice where i can get it, Detail specification for Transformer where below
1) 50 KVA@50HZ, primary voltage 33 kv and secondry voltage is 415-480v ( Two Taps )
2) 100 KVA@50HZ, primary voltage 33 kv and secondry voltage is 415-480v ( Two Taps )
3) 150 KVA@50HZ, primary voltage 33 kv and secondry voltage is 415-480v ( Two Taps )
Re: Transformer
05/21/2007 11:58 PM
no problem, I can manage it. write to me.
Good Answers: 42
Re: Transformer
05/22/2007 12:12 AM
In Canada,
I would use Hammond or Rex
Re: Transformer
05/22/2007 8:27 AM
This information is not enough to make a good purchase.
The following might be asked to the project engineer, or the one who asked for the purchase:
-what is the purpose of the transformers?
-wiil them be used indoor or outdoor?
-will them be dry or oil imersed?
-what is the local temperature range?
-how much room do you have to instal it(height, width and the third dimension)?
-which standard must the transformer follow?
-what is the minimum allowed impedance?
-state the limits of the supply(eg: no connectors shall be supplied with the transformer)
-list the accessories according to the standards
-define the auxiliary voltage for the ancillaries, such as thermometer, safety valve, buchholz, and so on
I think that this will allow the manufacturer to provide a good quotation.
Regards
Good Answers: 42
Re: Transformer
06/16/2007 1:49 PM
Hi,
The second advice is well written . Transformer purchase is not like buying nuts and bolts. It is a very important decision and need the advice of an experienced Electrical Engineer. The specification of the Transformer has to be made as per the correct requirement , utility, future expansion ,Location (outdoor/ Indoor ) , OFT/ CRT and many many more technical parameters . Specification should include pre delivery tests (Type Test and routine Tests ). So consult a competent Electrical Engineer before floating quotations.
Register to Reply 4 comments
cnpower (1); elbf2801 (1); GW (1); V.I.Abraham (1)
