Previous in Forum: 1998 Chevy Cavalier Won't Start   Next in Forum: Tiny V-12 Engine
Toyota Camry 2008
11/09/2012 10:28 AM
hi all
would you please help me on this
i am looking for wiring diagram for youta camry 2008, there is problem with the automatic transmission is not shifting even from speed one and i dont know if its sensor problem or module problem
i appreciate any advice you could supply
many thanks
Re: toyota camry 2008
11/09/2012 10:37 AM
I have no idea if this is helpful or not, but I'll just leave this here:
http://wiringcamry2008.blogspot.com/
I'm willing to bet every member on this site is more technically inclined about "Automotives" than me. They can probably help you out more!
The first law of thermodynamics is you do NOT talk about thermodynamics.
11/09/2012 10:44 AM
If you are a 'Fix My Car' sort of person, you should invest in one of these:
Haynes or Chilton... I usually buy one of each for my automobiles.
11/09/2012 4:27 PM
hi mr doorman
thanks for your reply,
to be honest, i am from libya and i can not buy online, we dont have this technology yet. and i could not find any printed copy here in the shops.
i already checked the Haynes website and it seams every thing is in this manual.
maybe you can help me out,
if you dont mind maybe you send me infos to send you the money and then you send me pdf copy on my email address.
if you dont mind
many thanks
Re: Toyota Camry 2008
11/09/2012 11:25 PM
Something you may wish to try is to 'reset' the transmission module by disconnecting the battery connection for 5 to 10 minutes. Some modules get 'stuck' in a limp home mode and removing the supply voltage from the module long enough to discharge the internal capacitors clears the problem.
If this quick and easy trick doesn't fix it, see the posts above.
Good luck with your quest.
11/13/2012 4:15 AM
hi i think u need to visit automotix.net it has all the diagrams for your car.hope this will help.
myshofer
Brave Sir Robin (1); Doorman (1); electric (1); Mizuti (1); myshofer (1)
