Previous in Forum: Metal Price List   Next in Forum: Which Stepper Motor Configuration to Choose?
10 comments
3D Solid Model Req'd - 37 Degree JIC Hose End
12/05/2012 1:41 PM
Greetings.
I need a 3D solid model of a 37 deg JIC hose end, Parker p/n 13943-16-16. Parker's website indicates a .stp file is available for download, but my computer locks up when I try the download. A search of the internet turns up nothing. Does anyone out there have a model stashed away you could share? I'm using Inventor 2012 Pro, so a native file format [.ipt] is desirable, but a neutral file format might work too.
Thanks in advance.
5
Good Answers: 101
Re: 3D Solid Model Req'd - 37 Degree JIC Hose End
12/05/2012 2:47 PM
I'll send you a PM for your email address... I have the model open right now.
12/05/2012 3:13 PM
A PUBLIC thank you for your help!
Good Answers: 101
12/05/2012 4:39 PM
You are very welcome!
CR4 is a good place.
12/05/2012 3:24 PM
This is the sort of interaction that makes CR4 what it is.
GA vote from me.
12/05/2012 3:28 PM
Agreed. Fun, informative and helpful!
Good Answers: 119
12/06/2012 9:52 AM
Ahh, too little too late.
If'n ya need anything else Parker, let me know. I've got a ton of their ends, hoses and firesleeves as Inv 2012 .ipt files.
Hooker
12/06/2012 9:57 AM
Will do! Thanks!
I've usually been successful with Parker's CAD library. This one part, however, just didn't want to cooperate.
Good Answers: 119
12/06/2012 10:25 AM
Every time I've run into a problem like that it's mostly our IT dept's fault. They have a system that caches download files onto a local server so that if you try to download the file a second time it gets it from our server instead of the source. This is supposed to be a convenience to our users as it's faster to move stuff across our network than across the internet.
Soooo... if you get bad data the first time, it's cached in our servers and you get bad data every time, for that particular file.
I've had to complain to IT several times to clean out this download cache so I could try for a clean copy.
Not saying that's what is your problem with the parker part but I've occasionally seen the issue with downloaded step files.
Hooker
Good Answers: 101
12/06/2012 11:48 AM
You could always try it again, and save it under a new filename...
Good Answers: 119
12/06/2012 3:21 PM
That depends on the source, system, your network infrastructure, browser and a few other variables like IT policies. Not all downloads give you the opportunity to save under other than what the source provides.
ie, I can't do that here.
Hooker
Register to Reply 10 comments
Doorman (1); Hooker (3); RVZ717 (3); Steve of the North (3)
