Previous in Forum: Joining PET Plastic   Next in Forum: Engineering Uses for Duct Tape
10 comments
Why are Disposable Batteries Called Primary?
12/07/2012 12:56 PM
Sorry for basic question and I did try and ask google. Why are disposable batteries called primary and rechargeables called secondary?
Re: Why are disposable batteries called primary?
12/07/2012 1:13 PM
I bet there is a reason , maybe buried in the history of electronics.
12/09/2012 7:08 AM
Well, look there, then. That's what books are for, Mildred.
Good moaning!
12/09/2012 11:44 AM
Books are good ,and in truth probably cant be done without, but forums allow access to some real wizards.
12/07/2012 1:44 PM
Hmmmnm, an interesting question.
I find this explanation from Wikipedia: "It is known as a secondary cell because its electrochemical reactions are electrically reversible." This, to me, is not really a satisfactory answer. I find nothing about just why the terms primary and secondary are selected and used, which is your question.
Wikipedia, Primary Cell Secondary Cell
12/07/2012 1:55 PM
Thanks for your reply. That is interesting.
Good Answers: 46
Re: Why are Disposable Batteries Called Primary?
12/07/2012 2:47 PM
Here a thought on primary/secondary cell naming.
"Prior to the rise of electrical generators and electrical power grids from around the end of the 19th century, batteries were the main source of electricity." From here.
As power generation became more reliable and equipment switched from battery to the "grid". Rechargeable batteries became the secondary power source because they could be recharged when power from the "grid" was "on". When it was not, the "secondary" source supplied the power.
Just a WAG on my part. What do you all think?
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
12/07/2012 4:33 PM
Good thoughts. Some guessing from me....I wonder if there was a specific category of equipment (maybe car/tank/lorry/mill generator) that used both types? Maybe the primary battery was used to supply the exciter coil in an alternator (maybe wrong terms?) and then the secondary battery could be charged from alternators output. I did more googling on this and the answer is not to be conclusively found.
12/07/2012 5:10 PM
Correction to my muddle thinking. It was not an exciter coil but a dynamo called the exciter that supplied the field coil in a larger generator so it could get going. I think.
Good Answers: 266
12/08/2012 9:28 AM
Primary because there is one chemical action involved to produce the current until the battery is drained
Secondary because there are two chemical actions one in producing the current and one in charging.
12/08/2012 10:30 AM
Thankyou ozzb, that makes sense.
Register to Reply 10 comments
Crabtree (1); Doorman (1); metalSmiths (1); ozzb (1); Tank Circuit (6)
