Previous in Forum: Auma India Actuator Not Operating in Local Mode   Next in Forum: Temperature/Humidity Sensor/Controller
Humidity Meter for Running Fabric
12/18/2012 3:37 AM
Hi to all,
This is Raees and i am working on case in which i require a humidity meter with rolling type sensor for running fabric and humidity range should be 0 ~ 100% RH. Please suggest any appropriate model at this application, end user is textile unit.
Best Regards,
Raees Butt
Good Answers: 34
Re: Humidity meter for running fabric
12/18/2012 4:55 AM
Good Answers: 16
Re: Humidity Meter for Running Fabric
12/18/2012 10:32 PM
For measuring the moisture content of powders we use a non-contact sensor. Curious if it would also measure the moisture of fabric.
Click for info: MoistTech IR-3000.
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
12/19/2012 12:14 PM
12/19/2012 12:21 PM
The fabric or textile type moisture monitures normally use a regain scale instead of relative humidity,Especially the roller resistivity contact type that you seek.
Regain refers to the amount of moisture regained by fabric if left at normal atmospheric conditions.With 100% cotton, for instance this is 6.5 to 7 %.
Fiber blends will affect this reading.
Strandberg has been doing this for over 40 years, so they can help you.
google: Strandberg Engineering Laboratories
Register to Reply 4 comments
Delmar (1); HiTekRedNek (2); Joshi (1)
