Previous in Forum: How to Work in Quartz Glass Tube?   Next in Forum: More Consultant Principle Diagram of Milk Filling Machine
Solution Annealing As Per 'Nace' for 304l & 316l
12/20/2012 2:44 AM
In Bibliography of NACE Nstandard ASTM A 182 standard is referred . For Austenitic Stainless Steel Flange ( F 304L , F 316L .) with additional requirement of NACE MR 0103 ,NACE MR 0175 and ISO 15156 , we assume that heat treatment as per clause 7.3.1( direct quenching after hot working at specified temperature ) is acceptable , Kindly let us know whether our assumsion is acceptable to NACE or not?
In general practice forged flanges of above said material are quench in water tank subsequent to the forging , as it considered solution annealing is it correct?
V . D . DEODHAR .
Re: Solution Annealing As Per 'Nace' for 304l & 316l
12/20/2012 8:43 AM
Clause 7.3.1 took from which standard? ASTM A 182 or NACE MR0103 or NACE MR0175 or ISO 15156??
12/31/2012 4:08 AM
The referred clause is from ASTM A182-2012 Standard under the Heading of Heat treatment.
12/31/2012 6:51 AM
There is no 7.3.1 clause mentioned below 'heat treatment' heading in ASTM A 182!The exact clause number is 6.3.1
6.3.1 Alternatively, immediately following hot working,while the temperature of the forging is not less than the minimum solutioning temperature specified in Table 1, forgings made from austenitic grades (except grades F 304H, F 316H, F 321, F 321H, F 347, F 347H, F 348, and F 348H) may be individually rapidly quenched in accordance with the requirements of Table 1.
01/08/2013 2:28 AM
Dear sir,
clause is 7.3.1 as per A182/A182M - 12a.
austenitic and ferritic-austenitic stainl' els shaH be heat
treat quirements of 7. Table 1.
7.3.1 Alternatively. immediately following hot w . 'ng.
while the temperature of the forging is not less than e
minimum solution annealing temperature specified in Table
forgings made from austenitic grades (except grades F 304H,.
309H. F 310. F 31OH,F 316H, F 321, F 321H. F 347. F 341:"'"
F 348, F 348H. F 45, and F 56) may be individually rap)ttly
hed in accordance with the requirements of Tab 1.
7.3.~:suPPlementary Requirement :Sirtl
If you give your mail id, then I can send you pdf copy of ' A182 /A182M - 12a '
V.D.DEODHAR.
01/08/2013 12:17 PM
You may be right as per latest ASTM document.I checked ASME SA-182/SA-182M ,2010 edition only.
12/20/2012 6:37 PM
You would need to contact NACE directly for a ruling.
NACE: Home
Register to Reply 6 comments
Anonymous Poster (3); lyn (1); vidyadhar deodhar (2)
