Previous in Forum: Portal Denial System Electrolaser Intruder Zapper   Next in Forum: Your most recent project for "fun"
Pressure switch in gas furnace
05/24/2007 3:29 AM
Hi
- does somebody know who are the US manufacturers of "pressure switches" used in gas furnaces to confirm that combustion fan is working ? ( negative pressure switch)
some information about reference identifying products
- what' s the average price of gas manufacturer buying this pressure switch ?
thanks in advance for asap reply to my urgent matter
rgds , Phil
Pathfinder Tags: gas furnace
Re: Pressure switch in gas furnace
05/25/2007 12:11 PM
In my experience, these are usually flow switches rather than pressure sensors per se. A lollipop-shaped metal arm extends in to the flow path of the air moved by the fan, and is connected to a simple contact switch. The moving air pushes against the broad head of the lollipop, deflecting it and putting pressure on the switch. Dead simple, cheap, and low tech. Use an off-the-shelf microswitch and a pair of tin snips to fab one in 5 minutes or less
If all else fails, read the directions. That's if, and only if.
05/30/2007 10:38 AM
List of Manufacturers Cleveland,Antunes, honeywell,robertshaw-white. I am talking airproving switches commonly used on power burners boilers etc. Most common are Cleveland and Antunes
05/30/2007 12:36 PM
thanks
do you have pricng for big quantities to Oem's ?
rgds
05/30/2007 12:34 PM
thanks for comments
y're right for older furnaces ; for new ones pressure switches
do you know Oem prices for both types ( price for big quantity )
for 2 stage gas furnaces where 2 pressure switches used , can you imagine if future solution could be a pressure sensor ( giving information electronically to control board ) ?
rgds
Register to Reply 4 comments
Anonymous Poster (1); ktel60 (1); philed (2)
