G'day All.
I have a 2 sets of 24vdc perm magnet motors, 700w,per set. being controlled by a 4QD controller. Forward and reverse will be used. Full load current is 36 amps, not sure what the controller will do to this, under different loads and speeds.
Batteries (100ah) and alternator (100amp) charging.
I have Panel meters and shunts to measure current flow.
1. I wish to measure Total Current flow.
2. I wish to measure current flow through 1 set of motors.
The Question relates to both measurements that I wish to observe.
Frinstance. 700w motors, I have a 75mv shunt, and a Panel meter scaled to suit. I imagine that there will be about < 50 amps. I'm guessing.
But it doesn't matter, as I have larger shunts and meters, ie shunts are 50mv and 75mv, and meters to suit 30, 50 75, and 100 amps.
All of the panel meters read 0 30 in one direction only. As distinct from some meters that read -30 0 +30., which is what I would like, but you guessed it, I am going the hard way....! It's all a matter of what I have.
I came up with a cunning plan to feed the meter wires from the shunt into a Shottky bridge rectifier, Bingo. I will read the current flowing in both directions.
Now I do not really, really, need, to know the current in both directions. But nice if I can.
So there is a problem. or 2 or 3. I haven't wired this lot up as yet, about another month to go., and I'll be ready for testing.
1. I presume that a reverse current will damage my meters....?rev voltage to meter.
2. The voltage drop across the bridge will sink my cunning plan, to measure both directions....!
Ref 1. I could bugger off the bridge, and a "relay Axe or chainsaw" to sense reverse, (or the "null") and disconnect the meter . There will be a "null" period between F/R. So I would read fwd current flow only.
Ref 2. Measure the Voltage drop across the bridge, and amplify it...I am not really ..... where..... going ..... help...??????
How can I get this lot running. R
ef 2. preferably, but the simplest way is Ref 1, I would guess.
It is an Electric driven Tram, 7 1/4" gauge. Photo of build. I will be donating this to the Volunteers at the Rockhampton Heritage Village, to run on their new track.
In anticipation, begging bowl in hand,
Mark N.
Qld Australia.
PS. I tend to be better builder, than I am a Designer...?
PPS. I am not a good builder
