Previous in Forum: Metal Recovery From Slag   Next in Forum: Designing Agrowaste Composite Boards
Solar Energy
12/29/2012 4:31 AM
Dears; Could you advice me the symplest sollar energy system to fix for a small house??
Re: sollar energy
12/29/2012 7:33 AM
for domestic hot water?
Re: solar energy
12/29/2012 8:22 AM
In the northern hemisphere the simplest solar energy system is to face the windows south. Hang insulating curtains. Open or close these curtains when appropriate.
Good Answers: 445
Re: Solar Energy
12/29/2012 9:51 PM
If you have access to black plastic pipe you can lay it on the ground or put it on your south-facing roof. 3/4 inch holds 0.0206 gallons per foot, 1 inch holds .0346, so 100 ft will provide about 2-3.5 gallons of hot water after about an hour in bright sun, assuming you are in a hot part of the world. No pump required if you have a holding tank on your roof.
Register to Reply 3 comments
Fredski (1); RAMConsult (1); redfred (1)
