Previous in Forum: How to Increase Mileage for a 2008 F250 Diesel Pickup   Next in Forum: Piston Rings Installation
V-Twin Harley Engine
01/13/2013 9:23 AM
How does the injection timing happens in a V-Twin Harley's engine. How does the overlap of valve happens and how does the two cylinders contribute in giving more power than a a single cylinder engine.( I understand there are 2 cylinders, but I am just looking out for some quantifiable data to understand it better)
Re: V-Twin Harley Engine
01/13/2013 9:39 AM
01/13/2013 10:24 AM
With this and your other post it sounds like you are rebuilding a Harley engine, if so, give year and displacement.
01/13/2013 10:39 AM
Must be fairly new if fuel injected.
01/14/2013 9:54 AM
Actually no, I just happened to visit harley's plant, and became curious about its engine
01/13/2013 10:58 AM
"EFI systems allow fuel and ignition timing changes to be made electronically, instead of mechanically changing jetting. For tuning EFI, two options are available: A self-contained control unit requiring no computer interface, or a computer-based software program that can modify the instructions stored in the stock ECM. The selfcontained non-computer interface units allow fuel flow to be quickly adjusted on mildly modified engines. Software-based tuning systems are more comprehensive and intended for both mildly and heavily modified EFI engines. Software systems allow both fuel flow and ignition timing changes to be made to the ECM's writer. These procedures are commonly referred to as replacing the ECM's fuel map. "
http://www.harley-davidson-hangout.com/forum/hdrcgb-virtual-rally/86100-simple-animation-explain-complex-principles.html
01/13/2013 11:27 AM
study the design of an old airplane radial engine (especially the crank design and you'll see how the placement of the rods in relation to the crank affect crank momentum, the engine design was borrowed from a radial
01/14/2013 12:55 AM
I'll throw in two bobs worth re "more power with more cylinders".
The answer is all to do with combustion efficiency and mass/inertia/elasticity effects which impact on engine speed.
As a general rule the bigger combustion chambers are more efficient in the sense that there is less area in relation to the fuel charge for heat to escape, though size probably works against getting a good quick complete burn.
The other major effect is that large pistons and large throw crankshafts get heavier faster than they get stronger, so that small always spins faster - and as you know power is the product of torque x revs.
But all "rules" have their limits and too many pistons mean that friction and heat losses become a problem that overtakes the speed advantage. One relative constant that is relatively independent of piston size/number if the limiting piston ring velocity.
These arguments also go to why over-square engines (where the bore is greater than the stroke) are more powerful than under-square ones.
Register to Reply 7 comments
chetan11 (1); Fredski (1); JPool (1); lyn (2); SolarEagle (1); TrevorM (1)
