Previous in Forum: Shunt Coil   Next in Forum: Relays and Timers
Rock Saw DC Motor
01/14/2013 7:59 PM
My 20 inch rock saw has 2 motors. one drives the saw blade and the other drive a 1/2 inch rod that is threaded 20 threads per inch. The motor that drives the 1/2 inch thread rod died. It was a single speed motor. I what to replace it with a variable speed reversable motor. Can anyone help me with this?
Re: Rock Saw DC Motor
01/14/2013 8:28 PM
What's the voltage and amp draw, frame size, mounting requirements, rpm range, copy any tags on equipment and post info, pictures would be helpful...
How about this?
01/15/2013 4:40 AM
Start here.
United States - Member - New Member Safety - Hazmat - New Member
01/16/2013 12:21 AM
Im assuming the motor you describe is the feed motor that pushes the rock into the blade. I can understand why you would want a variable speed but is there an adjustment to feed faster or slower depending on the type of rock? Its been many years (40) since I did any lapidary work but as I recall "Graingers" was the place for saws and parts related.
Dont squat with your spurs on, and always drink upstream from the herd.
Register to Reply 3 comments
Randall (1); SolarEagle (1); spaceracer (1)
